ARP Spoofing
there are so many arp entries that is not from my network. all the ips are from the isp from where i have internet.
my internet ip is 172.19.50.55/24
gateway is 172.19.50.1
my lan is 192.168.0.0/24
i get arp entries from 172.19.50.0/24 network.
is this spoofing? how can i control it so that there won’t be any entries from that network except the gateway?
Your ISP does this:
  • you don’t get a public IP adress. Instead you are given a private one, which is being masqueraded (NAT)
  • the ISP doesn’t properly implement user isolation, this mean that all customers within your subnet can easily abuse the providers network for direct communication.
no no i got public ip. that private ip was just an example.
i have a public ip of 117.2.56.8/24 with gateway 117.2.56.1.
and there are entries in arp like 117.2.56.5, 117.2.56.227 etc. sometimes there are 4,5 entries and sometimes there are 10-15 entries.
What measures can be taken?
you cannot take measures against this.
if you block such arp entries you won’t be able to communicate with the other customers of you ISP.
