I’m using a rather strange configuration on my RB750 with ROS v6.19:
ether1 has 10.12.123.123 255.255.0.0
ether2 has 10.12.123.124 and the same subnet as ether1.
and I’m using a routing protocol.
My problem is that the routing protocol needs some time to start working properly and something stops working.
In this case I try to connect to the routerboard (using winbox&webfig), but it seems that the answer-packets are leaving through the wrong interface. When i disable ether2 i have no problem to connect using ether1. When i disable ether1 I have no problem to connect using ether2. But when both interfaces are active it does not work.
I cannot understand this, because only one interface should have the ARP entry of my notebook, so why the answer-packets get stuck in nowhere?
