ARP Watch Script
:local ipaddr;
:local macaddr;
:local iface;
:local macoui;
:local macnotfound;
:local ipnotfound;
:local oldmac;
:local oldip;
/ip arp
:foreach i in=[ /ip arp find ] do={
  :set ipaddr [get $i address]
  :set macaddr [get $i mac-address]
  :set iface [get $i interface]
  :if ([/ip firewall address-list find list="arpwatch" comment=$macaddr] = "") do {
     :set macnotfound "true";
  } else={
     :set macnotfound "false";
  :if ([/ip firewall address-list find list="arpwatch" address=$ipaddr] = "") do {
     :set ipnotfound "true";
  }  else={
     :set ipnotfound "false";
  :if ( $macnotfound = "true" && $ipnotfound = "true" ) do {
    /ip firewall address-list add list="arpwatch" address=$ipaddr comment=$macaddr disabled=yes
    :log warning ("New MAC address: $macaddr ($ipaddr@$iface)")
    :set macoui ([:tostr [:pick $macaddr 0]] . [:tostr [:pick $macaddr 1]] . [:tostr [:pick $macaddr 3]] . [:tostr [:pick $macaddr 4]] . [:tostr [:pick $macaddr 6]] . [:tostr [:pick $macaddr 7]])
    /tool e-mail send to="arpwatch@ken-tennwireless.com" subject="ARPWatch - Info" body="New ARP Entry: $macaddr ($ipaddr@$iface)\r\n\r\nManufacturer: http://standards.ieee.org/cgi-bin/ouisearch?$macoui"
  :if ( $macnotfound = "false" && $ipnotfound = "true" ) do {
     :foreach ip in=[/ip firewall address-list find list="arpwatch" comment=$macaddr] do={
       :set oldip [get $ip address]
     /ip firewall address-list remove [/ip firewall address-list find address=$oldip]
    /tool e-mail send to="arpwatch@ken-tennwireless.com" subject="ARPWatch - Warning" body="WARNING: IP Address Changed: $oldip -> $ipaddr ($ipaddr@$iface)\r\n\r\nManufacturer: http://standards.ieee.org/cgi-bin/ouisearch?$macoui"
  :if ( $macnotfound = "true" && $ipnotfound = "false" ) do {
    :foreach mac in=[/ip firewall address-list find list="arpwatch" address=$ipaddr] do={
       :set oldmac [get $mac comment]
     /ip firewall address-list remove [/ip firewall address-list find comment=$oldmac]
    /tool e-mail send to="arpwatch@ken-tennwireless.com" subject="ARPWatch - Warning" body="WARNING: MAC Address Changed: $oldmac -> $macaddr ($ipaddr@$iface)\r\n\r\nManufacturer: http://standards.ieee.org/cgi-bin/ouisearch?$macoui"
  :if ( $macnotfound = "false" && $ipnotfound = "false" ) do {
    :log warning ("IP: $ipaddr and MAC: $macaddr already have been added")
1:51pm 1/4/13: fixed the syntax dumbspaces between :if (
Let me know if it works?
Thanks,
Devin
Does anyone have any problems using this script?
It seems like no one has actually used it… perhaps because they don’t need to.
What exactly is the purpose anyway? Just a logger for any changes in the ARP list? If people need this in realtime, an API application is a better choice (and is trivial to write with the “listen” command).
Hello :slight_smile:
I confirm!
It works!
I changed the DHCP server lease to 365 days and I scheduled to run the script every 24 hours :wink:
And the false alarms are reduced to zero.
Thank you for the script.
Best Regards!
sorry, what this script does?
It was posted in 2013, so not sure OP is still using this forum :slight_smile:
In short, it just create and updates an arp table list that sends log and email when new stuff appears or changes.
Se my comments in the script (just a quick review, may be som errors.)
PS you can also send the DHCP logs to get more or less the samme information.
:local ipaddr;
:local macaddr;
:local iface;
:local macoui;
:local macnotfound;
:local ipnotfound;
:local oldmac;
:local oldip;
/ip arp
#Lists all data in /ip arp table
  #If mac found in arpwarch list set macnotfound true, else false
  } else={
  #If IP found in arpwatch list set ipnotfound true, else false
  }  else={
  #If not mac and nor ip are found, add both to address list and give a warning and send an email
  #If mac found but IP not, find old IP, and replace with new and send email
  #If mac not found, but ip found, find ip and update mac and send email
Script is ok, but do miss som = after do.
I do mostly get the same information from my DHCP script.
This script do also get the interface or bridge info and info from devices with static IP.
DHCP gives more info about the device.
