Aruba Instant On 1930 - Mikrotik wAP ac - no connection
Hi.
Maybe someone has the same problem and can help me out. I use Mikrotik wAP ac as access point on my network. Everthing works fine until I updated Mikrotik wAP ac from 7.13.3 to 7.14. The connection to the Aruba switch broke. Neighbor discovery works, no ping possible. I cannot see any other devices on the neighbor discovery - only the Aruba switch. When i downgrade the wAP ac to 7.13.3 everything works fine. The problem occours on different wAP ac but only in combination with the Arube instant on switch. All other switches dont have this problem. Does anyone know if there have been made changes in the firmware that might cause this problem.
Switch: Aruba Instant On 1930 24G Class4 PoE 4SFP/SFP+ 195W Switch JL683B Firmware 2.8 and 3.0 tested
Access Point: Mikrotik wAP ac
Greetings Thomas
config_wap_ac.txt (1.97 KB)
How are you setting up VLAN if any?
