[ASK] building HotSpot network
I’m sorta new on mikrotik, though I successfully made a simple router, through srcnat from internet to my computer clients. I’m still having trouble on making the hotspot network. I tried, but never success, the hotspot clients always fail on connecting to the network(the mikrotik hotspot login page doesn’t show up). here’s the image of my current network:
and here’s the image of the network i’m trying to build up and failed:
I’d be thankful if anyone can give me a quick tutorial, how to make it works…
why don’t you go like this:
/ip hotspot setup
and there should be a wizard that will guide you through the setup process and I think it’s easy
remember set your routers primary and secondary dns
when i mention “I tried, but never success”, i was refering that i already tested the "/ip hotspot setup " and carefully follow the guide of the setup. coz i failed on it, i think, perhaps i should get another way to set this thing up, manually, and that’s how i ended up here.
thanks anyway,
any other idea? pls
http://wiki.mikrotik.com/wiki/How_to_make_a_HotSpot_gateway
I’m guessing you have read the above howto in the wiki?
One hotspot per interface, so just use two to do what you want.
