saktie
1
Dear All,
I have a problem with my RB450g , ie can not ping the hostname with the following error:
[admin@ge-01.xxx.net] > ping www.yahoo.com
invalid value for argument address
but the client can ping the hostname
note:
ip dns 202.129.189.59
ip dns 202.129.189.61
I also tried google dns 8.8.8.8 but still the same result
regards
saktie
Can you ping the dns server ips?
The client is using the same dns server ips? Can you post “/ip dns print”?
saktie
5
ip dns pr
servers: 202.129.189.59,8.8.8.8
allow-remote-requests: yes
max-udp-packet-size: 512
cache-size: 5096KiB
cache-max-ttl: 1w
cache-used: 25KiB
the last configuration
If you use the CLI, use this at a prompt:
:put [:resolve www.yahoo.com]
You should get an ip address.
What version RouterOS are you using?
