Hi all, thanks for coming.
I have RouterOS 6.42.6 x86. I’m managing a network with open access (everyone can connect to it). Any client that are connected to my network get IP from DHCP server and allocated 1Mbps on upload/download (using queue tree HTB).
It’s very inefficient if I put every single mangle and queue for whole IP address (/24). So I decide to use script. I found an interesting article about DHCP Server https://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server#DHCP_Options.
The idea is, if user get an IP from dhcp server, the script for assigning IP will be triggered (triggered by $leaseBound = “1”) and makes mangle & queue then comment them with IP address (with variable $leaseActIP). So far, it works for creating mangle and queue. But when user deassign IP address, $leaseActIP get blank and fail to remove queue and mangle.
I just want to ask, is there any built-in variable that indicate deassigned user’s IP. So I can remove queue and mangle. Or maybe, you have another workaround for my problem.
I appreciate every comment
