i use 104 firewall filter rules in my mikrotik RB951Ui-2nd
its to many or just fine?
I use 7 rules in my filter table - only 4 are really needed, as the last 3 simply block IP4 from leaking onto my IPv6-only test SSID. This includes input and forward rules.
1: input: allow established,related
2: input: allow ICMP
3: input: allow whitelisted sources
4: input: drop in-interface=wan
Done.
(5, 6, and 7 = drop IPv4 input from, output to, or forwarding from the IPv6-only network)
Granted, I have no NAT pinholes, etc, which I want to limit access to, or any outgoing stuff that I want to deny… but this policy is quite simple: if I asked for it, then accept it. If it’s control messaging (ICMP) then accept it. If someone I trust on the outside asks for it, then accept it. Otherwise, throw it away. (blocking pings is against my religion - it doesn’t really enhance your security anyway)
what throughput you achieve with that config on that rb951?
I would say it depends on a couple things:
Are you getting the throughput you want/need and is it getting too complicated for you to manage/maintain?
If you use custom chains/jumps and order the rules properly then the rule count can be high with a manageable effect on performance. This will also help document and manage your rules.
But this is not typical situation. Typically the router has to not only protect itself but also the network hidden by nat behind it. To have not general drop rule in forward chain means to let pass everything that was not eventually matched and dropped by individual forward chain rule. I agree with allowing icmp religion but my religion says in addition: and finally drop everything in all chains.
Well, since there’s NAT involved, a default drop in-interface=wan for the forward chain is somewhat redundant, but it’s good to be explicit in configurations.
FWIW my IPv6 forward chain has a default drop policy from the Internet. ![]()
