Ask for a test RB711. Self country change Quickset! ver 6.2
If you have few minutes…
  1. Take RB711-5Hn-MMCX
  2. Version 6.2 is necessary.
  3. Reset configuration - NO default settings, reboot.
  4. Using Winboxa enable radio interface and set country to poland or latvia
  5. Close Winbox and relogin with it.
  6. Click Quickset. ---- At this point on 2 different machines: W7x32 and W8x64 Winbox crashes and next login in Wireless >> interfaces I can see: “no_country_set”!!!
  7. If your Winbox crashing? If yes, what country do you have in Wireless >> interfaces?
My friend on polish forum confirmed the problem on XP sp3.
thank you for the report, we will fix this in the next RouterOS version.
that would be great
Problem still exists in 6.3 version… :frowning:
It didn’t help, there is still problem in Winbox’s quickset
*) webfig - fixed problem when opening quickset page country
