ASK !! HELP ME to SETTING RB 411U 3G Card
I have a ploblem with my RB411u Configuration,
i am using sierra wireless mc8775 3 card, i am ambigu because in /system resource usb print
[admin@MikroTik] /system> resource usb print
 # DEVICE VENDOR                                    NAME                                   SPEED
 0 2:1                                              RB400 EHCI                             480 Mbps
 1 1:1                                              RB400 OHCI                             12 Mbps
 2 1:3    HP                                        HP hs2300 HSDPA Broadband Wireless ... 12 Mbps
vendor in not detected sierraa wireless.
Please Help me!
Thanks before! from mikrotik bali!
What is the problem?
Do you have anything at /port print?
3G card documentation and configuration example,
http://wiki.mikrotik.com/wiki/Option_Globetrotter_HSDPA_USB_Modem
I have noted a problem using ROS 4.12 with a Sierra Wireless MC8775 on a RB411U ...
As shown below, the MC8775 is recognised as an HP hs2300 using "/system resouce usb print". The port regularly changes between being active and inactive - when this happens, there is an incremental number update under /system resource usb print
Therefore, I cannot get the MC8775 (or HP hs2300 working) in the RB411U...
Is there a solution please?
2 1:72 HP HP hs2300 HSDPA Br... 12 Mbps
A bit later ..... /system> resource usb print
2 1:75 HP HP hs2300 HSDPA Broadband Wireless Module 12 Mbps
