Hello, I’m using rb112 with 1 eth & 1 wlan interface
The internet is coming from eth1, IP : 192.168.152.229
Route static : 0.0.0.0/0 to 192.168.152.229
I configure HotSpot on Virtual AP, Gateway : 10.5.50.1, IP Range : 10.5.50.2-10.5.50.254
It works fine, Hotspot client can access the internet.
But, when I configure HotSpot on eth1, Gateway : 10.5.51.1, , IP Range : 10.5.51.2-10.5.51.254, all hotspot client from eth & wlan can’t access the internet.
Can someone help me ?
I guess that the problem is in NAT Maquarade because eth1 now has 2 IP address : 192.168.152.229 and 10.5.51.1 (hotspot gateway on eth1), maybe the MT confused which is the public IP ?
Hello Inzra,
Exuse me but I’m a novice and I don’t know how to help you, maybe you can help me, I’m trying to configure hot spot on RB112 with r.os 2.9.43, i look for hot spot in section “IP” but if I enter “hot spot” the response is “not found”, also with winbox nowhere to be found section “hot spot” . Where are hot spot section?
Can you help me?
/ ip hotspot user profile
set default name=“default” idle-timeout=none keepalive-timeout=2m
status-autorefresh=1m shared-users=1 transparent-proxy=yes
open-status-page=always advertise=no
