[ask] how to limit only port 80
hi, how to limit only for browsing (port 80, etc)
TQ
Mangle: mark port 80 packets
Add queue with packet mark
do you want limit port 80 (queue) or only accept port 80 (firewall)
Max
hi
how can i accept browsing only and block the download ???
thnx
using http protocol everything is download, only difference is extension and size of file you are downloading
browsing is downloading. it is the same thing, there is nothing that separates these words.
You can set the burst rate to e.g. 192kBps and the maximum download limit to 32kBps. Make the burst threshold 15kBps and the burst period 1800s. This will allow for browsing only but will make downloads very slow.
open port 53 for DNS too.
Hi ;
i need to try this to make the priority goes to opening yahoo messenegr and browsing then the download .
i need to know why the brust time you set to 1800s not like 120s or less or more ?
buy the way i am using the following rules in firewall , will they help me to make the browsing go fast by limiting the number of sessions ?
add action=jump chain=forward comment="limiting connection" \
    connection-limit=30,32 disabled=no dst-port=80 in-interface=bridge1 \
    jump-target="band swallow" protocol=tcp
add action=jump chain=forward comment="" connection-limit=15,32 \
    connection-mark=ftp disabled=no jump-target="band swallow" protocol=tcp
add action=add-src-to-address-list address-list="band swallow" \
    address-list-timeout=5m chain="band swallow" comment="" disabled=no \
add action=jump chain="band swallow" comment="" disabled=no jump-target=drop \
    src-address-list="band swallow"
the first one to limit the number of sessions and the second one i just put in the firewall to limit the downloads per user .
waiting comments .
with best regards .
