Im using RB951Ui-2nD and when im using whatsapp in my mobile phone through wifi to mikrotik and its become slow when loading image in group chat or private chat in whatsapp
Anyone had same experience? and how to fix this issue?
Hi, I also see this behavior. Is there any chance you manage to get it solved? Thanks lots in advance
I have the same problem.
hello
i have 3 internet connections connecting to mikrotik using load balacing
when more than one connection is connectiong to the mikrotik i’m facing problem like reaching some websites and like whatsapp media is very slow to download (audio)
but when i disconnect other connection and leave just one all work fine
What is the problem??!!
here is my mikrotik configuration
# model = 750
add name=Bridge-Local protocol-mode=none
set [ find default-name=ether1 ] comment=WAN
set [ find default-name=ether2 ] comment=WAN
set [ find default-name=ether3 ] comment=WAN
set [ find default-name=ether4 ] comment=LAN
set [ find default-name=ether5 ] comment=LAN
add name=WAN
add exclude=WAN name=LAN
add name=dhcp_pool0 ranges=192.168.1.90-192.168.1.220
add address-pool=dhcp_pool0 disabled=no interface=Bridge-Local lease-time=1d \
name=dhcp1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=Bridge-Local interface=ether4
add bridge=Bridge-Local interface=ether5
set discover-interface-list=!WAN
add interface=ether1 list=WAN
add interface=ether2 list=WAN
add interface=ether3 list=WAN
add address=192.168.1.1/24 comment=defconf interface=Bridge-Local network=\
192.168.1.0
/ip dhcp-client
add add-default-route=no disabled=no interface=ether1 use-peer-dns=no \
use-peer-ntp=no
add add-default-route=no disabled=no interface=ether2 use-peer-dns=no
add add-default-route=no disabled=no interface=ether3 use-peer-dns=no
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8
/ip firewall address-list
add address=192.168.1.0/24 list=NAT_USERS
add action=accept chain=forward connection-state=established,related
add action=accept chain=input dst-port=8291 in-interface-list=!WAN protocol=\
tcp
add action=accept chain=input connection-state=established,related
add action=drop chain=input connection-state=invalid
add action=drop chain=input in-interface-list=WAN
/ip firewall mangle
add action=accept chain=prerouting in-interface=ether1
add action=accept chain=prerouting in-interface=ether2
add action=accept chain=prerouting in-interface=ether3
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=Bridge-Local new-connection-mark=WAN1_conn passthrough=yes \
per-connection-classifier=both-addresses:8/0 src-address-list=NAT_USERS
in-interface=Bridge-Local new-connection-mark=WAN2_conn passthrough=yes \
per-connection-classifier=both-addresses:8/1 src-address-list=NAT_USERS
in-interface=Bridge-Local new-connection-mark=WAN3_conn passthrough=yes \
per-connection-classifier=both-addresses:8/2 src-address-list=NAT_USERS
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=Bridge-Local new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=Bridge-Local new-routing-mark=to_WAN2
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
in-interface=Bridge-Local new-routing-mark=to_WAN3
add action=masquerade chain=srcnat out-interface-list=WAN src-address-list=\
NAT_USERS
add check-gateway=ping distance=1 gateway=192.168.4.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_WAN3
add check-gateway=ping distance=2 gateway=192.168.3.1
add check-gateway=ping disabled=yes distance=3 gateway=192.168.2.1
/system clock
set time-zone-name=Asia/Beirut
/system identity
set name=mikrotik
Some servers check that the client IP address is the same for all individual connections (TCP sessions) that are logically linked together - such as a download of an image to which a previously downloaded html document refers, but it’s just an unrealistic example for illustration of the idea as no one actually cares about this particular case.
So try changing both-addresses to src-address in the per-connection-classifier in all rules that use it. If it helps, you know the reason, and you have to evaluate the consequences of this change, i.e. how the number of LAN side clients and difference in bandwidth of the individual uplinks will impact the experience of the individual LAN clients. If there is a significant difference in bandwidth, you might need to adjust the rules to distribute the traffic among the uplinks in a ratio proportional to the ratio of their bandwidths. I.e. if uplink 1 has 10 Mbit/s, uplink 2 has 5, and uplink 3 has only 2, you need to send 5/17 of the connections via uplink 2, 2/17 via uplink 3, and the rest via uplink 1. In most cases the download bandwidth is the one that matters.
Dear
sorry i didn’t understand what i have to do
please
In all mangle rules that use per-connection-classifier, change per-connection-classifier=both-addresses to per-connection-classifier=src-address . If that fixes your issue, it makes sense to discuss the rest.
