[Ask] Multicast in mikrotik?
Dear All,
When i set up the multicast using this tutorial http://wiki.mikrotik.com/wiki/Manual:Multicast_detailed_example, I did not worked, then i try to use the bridge mode without using pim and it worked, but when i check it, the packet is sent by broadcast by the router. When sending packets to an IP multicast router, does the router sends it by broadcast?
Regards
Roy
I have same problem. Does anyone can help?
