Can anyone add some info here.
According to MT wiki about Nv2 AP Synchronization
“After Master AP is found the Slave AP will calculate the distance to the Master AP as it is possible that Master AP is located not on the same location”.
I got one Master-AP–ssid=test1, and one Slave-AP-ssid=test2
And im connection station to one of those APs.
Station can see only ONE ssid whether test1 or test2.
Distance betwene Master and Slave APs is’t more the 2m. That is for my lab at home.
is the distance matter for the client to chouse diferent APs?
