[ask] ping time unstable
i’ have the problem with my wireless PTP
interface wireless registration-table pr
INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 wlan2 00156D63DE96 00:15:6D:63:DE:96 no -51dBm@24Mbps 36Mb… 3w2d7h58m6s
1 wlan1 roofcyber 00:15:6D:63:DE:99 no -58dBm@18Mbps 36Mb… 3d16h48m12s
interface wi print advanced
0 R ;;; to_gdcyber
name=“wlan1” mtu=1500 mac-address=00:15:6D:63:DE:9E arp=enabled disable-running-check=no
interface-type=Atheros AR5413 radio-name=“rasela” mode=ap-bridge ssid=“XX1XX” area=“”
frequency-mode=superchannel country=japan5 antenna-gain=0 frequency=5490 band=5ghz-turbo
scan-list=5300-5500 rate-set=configured supported-rates-a/g=18Mbps,24Mbps,36Mbps,48Mbps
basic-rates-a/g=18Mbps,24Mbps,36Mbps,48Mbps max-station-count=2007 ack-timeout=50
tx-power-mode=default noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a
wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=yes
allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 hw-retries=4 frame-lifetime=0
adaptive-noise-immunity=none
1 R ;;; to_pluit_cyberx
name=“wlan2” mtu=1500 mac-address=00:15:6D:63:DE:9F arp=enabled disable-running-check=no
interface-type=Atheros AR5413 radio-name=“GunTur” mode=ap-bridge ssid=“Guntur” area=“”
frequency-mode=superchannel country=no_country_set antenna-gain=0 frequency=5700
band=5ghz-turbo scan-list=5500-5700 rate-set=configured supported-rates-a/g=24Mbps,36Mbps
basic-rates-a/g=24Mbps,36Mbps max-station-count=2007 ack-timeout=dynamic tx-power=17
tx-power-mode=all-rates-fixed noise-floor-threshold=default periodic-calibration=default
whether there is another setting for my wireless to be more optimal??
ping to wlan 0
10.0.0.2 64 byte ping: ttl=64 time=13 ms
10.0.0.2 64 byte ping: ttl=64 time=3 ms
10.0.0.2 64 byte ping: ttl=64 time=1 ms
10.0.0.2 64 byte ping: ttl=64 time=17 ms
10.0.0.2 64 byte ping: ttl=64 time=2 ms
10.0.0.2 64 byte ping: ttl=64 time=8 ms
10.0.0.2 64 byte ping: ttl=64 time=7 ms
10.0.0.2 64 byte ping: ttl=64 time=11 ms
10.0.0.2 64 byte ping: ttl=64 time=16 ms
10.0.0.2 64 byte ping: ttl=64 time<1 ms
10.0.0.2 64 byte ping: ttl=64 time=6 ms
10.0.0.2 64 byte ping: ttl=64 time=4 ms
10.0.0.2 64 byte ping: ttl=64 time=31 ms
10.0.0.2 64 byte ping: ttl=64 time=12 ms
10.0.0.2 64 byte ping: ttl=64 time=26 ms
ping to wlan 1
10.0.3.1 64 byte ping: ttl=64 time<1 ms
10.0.3.1 64 byte ping: ttl=64 time=1 ms
10.0.3.1 64 byte ping: ttl=64 time=2 ms
10.0.3.1 64 byte ping: ttl=64 time=10 ms
10.0.3.1 64 byte ping: ttl=64 time=21 ms
10.0.3.1 64 byte ping: ttl=64 time=11 ms
10.0.3.1 64 byte ping: ttl=64 time=3 ms
10.0.3.1 64 byte ping: ttl=64 time=12 ms
10.0.3.1 64 byte ping: ttl=64 time=13 ms
regards
saktie
What are your CCQ values? I bet they are not always 100/100% when sending heavy traffic? Sounds like the wireless is doing what it is supposed to do, it is seeing other traffic on the radio channel and is delaying transmission or retransmitting the packets. This is then causing latency.
What does a frequency scan show you about the traffic around you? Is it busy?
Choose a different channel, choose a different aerial that only “sees” your clients and less interference.
There are other options available in v4, such as turning off CSMA and only using nstreme polling to control packet timing. But go for the easy things first!
whether they could provide example settings to use
:smiley:
