Hi, how to ping to bridged modem either from LAN or MikroTik?
Here is my topology:
Internet — ADSL Modem (Bridge) — MikroTik — Switch — LAN
ADSL Modem (Bridge) = 10.0.0.1
MikroTik pppoe (ether1) = 10.0.0.2
MikroTik LAN (ether2) = 192.168.1.2
LAN = 192.168.1.xxx/24
Now I can’t ping from LAN to ADSL Modem (Bridge) and also I can’t even ping from MikroTik to ADSL Modem (Bridge), but both MikroTik and LAN can ping to google.com
I think it should be some routing to make this works.
yes… this is solved, thats my modem problem, i found out by plugging directly from pc to modem and I still can’t ping to modem…
then I reset modem and it works perfect…
I can ping and get to the configuration page on my modem from my LAN even though it’s in PPPoE bridged mode.
My LAN is 192.168.1.0/24 and the modem is on 192.168.2.254/24. I have set an extra address of 192.168.2.100/24 on the ether1-gateway port of my 751 which the modem is plugged into. The important thing is that the modem can be set to have a default gateway of 192.168.2.100 and also DNS is set to 192.168.2.100. Some modems don’t allow a manual gateway address on a LAN. Netcomm doesn’t appear to but Billion does as it lets you chose IPWAN or IPLAN for the gateway and DNS address. Because the Billion allows IPLAN gateways I can also still use the Billion’s VoIP function without any trouble.
