[ask] ploblem with bandwidth after ip firewall is actived on birdge setting
hello everyone i want to ask
i have some problem, i want to limit from one ip address on my bridge port, i had to checked “use ip firewall” on bridge → setting
then i make queue for 1 ip that i want to limit and i check it on speedtest and the bandwitdh is correct, but after i tested the other ip the bandwith does not full
can you all help me?
I dont fully understand, why did you enable your Bridge Firewall? What exactly do you want to limit ?
