[ASK] Router could not be ping from external network
HI,
I just bought a RB450G, remove the default configuration (bridges)
and put the ip public address in eth1, then connect it to a switch where my ISP radio were plugged.
however, i could not ping that ip public address from any external network.
i do not setup any firewall rule.
I use RouterOS 4.16
please kindly advise.
thanks a lot for your reply
if you need me to post any setup in the router, please advise. I have no where else to ask for…
You should post “/ip address”, “/ip route” and “/ip firewall filter”.
Hi SurferTim,
as requested
[admin@MikroTik] > /ip route pr
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 111.XX.YY.ZZZ/30 111.XX.YY.ZZZ ether1 0
[admin@MikroTik] > /ip firewall filter pr
[admin@MikroTik] > /ip address pr
ADDRESS NETWORK BROADCAST INTERFACE
0 111.XX.YY.ZZZ/30 111.XX.YY.ZZZ 111.XX.YY.ZZZ ether1
I do not see a default gateway in “/ip route”. There should be an entry like this:
add dst-address=0.0.0.0/0 gateway=xx.xx.xx.xx
The xx.xx.xx.xx should be the gateway issued by your ISP.
so you mean to say, if i add the ip default route
then any external network will be able to ping that public address?
i have contact my isp, they said they only able to ping that ip from the gateway’s ip address.
i will add the default route, and let you know the result.
Without a default route, you can only access (and respond to) your localnets. All should work fine with a default route.
Thanks SurferTim, it work like a charm!
i cant believe a simple default route is mandatory.
You’re welcome! And a default route is mandatory only if you want internet access. Localnet access does not require one. But I guess you know that now. :smiley:
