[ask] routing problem
dear all,
I got problem with routing. heres my network configuration
public (public ip) — (eth0)MT(eth1)(public and local IP) —(public and local IP)local
on local I have several clients, so some of them using private ip and other using public one.
oke lets it be like this ;
On MT :
192.168.1.1/24 (private ip)
222.124.34.1/30 (public ip)
On Client :
Client A 192.168.1.2/24
Client B 222.124.34.2/30
Both of clients (A and B) got no problem to access the internet, for client A I`m using src-nat and for client B just routing.
Problem is, Client A can not access Client B. I just try to put webserver on client B then try to browse it from client A. its not work.
Any ideaplease? I just try to put route static to dst-address=222.124.34.2 gw=222.124.34.1 still not work.
Thanks.
Sounds to me as though you do not have routes pro parley set up in mikrotik. Have to setup routes in order for mikrotik to know which interface or gateway to use to reach the clients. Has to ave a route for 192.168.1.0/24 and 222.124.34.0/30
