{ASK} script
i need script that will put user and password on “system user”, but i want to remove any other wich existing.
Does anyone have that script?
This should do:
:local username "some-user-name"
:local password "some-password"
/user
add name=$username password=$password group=full
:foreach u in=[find] do={
  :if ([get $u name] != $username) do={
    remove $u
mnohokrat dakujem :slight_smile:
Why do you loop? This should be sufficient:
/user {
remove [ find where name!=$username ]
