i got this scenario
i got VPN (l2tp+ipsec) router behind NAT
- And on my MAIN router i got NAT helper for my VPN router
nat
add action=dst-nat chain=dstnat comment=vpn dst-port=500,4500 protocol=udp to-addresses=192.168.x.x
add action=dst-nat chain=dstnat protocol=ipsec-esp to-addresses=192.168.x.x
The issue is, wherever i’m trying do vpn-l2tp+ipsec e.g to my company from my
network it doesn’t established, because of the NAT rules.
As soon as i disable them the works.
i want to keep those rules for my VPN router , but also i want to be able to connect to my vpn at work without disabling them.
