[ASK] WAN Speed problem
Hi everybody, I’m new to mikrotik dan new to this forum :slight_smile:
I am using RB450G with RouterOS v4.11 and 3 WAN.
My first WAN speed is 1.5Mbps, second WAN is 1Mbps and third WAN is 3Mbps.
My problem is most users complain that the browsing speed is too slow. What I see on Interface List is most traffic go to WAN1 which is “only” 1.5Mbps, some of the traffic goes to WAN2 dan WAN3. WAN2 is only 1/3 speed of WAN3, but get almost the same traffic with WAN3.
I think my current configuration is not optimize yet. If most traffic go to WAN3 which is the fastest one, my internet connection speed will improve.
Am I right? What should I do to make most users go to WAN3 so I can maximize the speed?
Thanks a lot :slight_smile:
BR,
Mike.
At the very least HINT at what load balancing method you’re using. Ideally post your config.
Wild stab, guess, whatever: use PCC and add statements so that the ratio between PCC matchers for each WAN line matches their actual speeds. In your case, the smallest common denominator is 0.5, so you would want to match WAN 1 three times, WAN 2 two times, and WAN3 six times.
It’s going to be hard to be more specific without more specific information from you.
Fewi, thanks a lot for the clue :slight_smile: I will try to figure it out.
Thanks again
The main thing to remember about load balancing in a MikroTik is it is based off of CONNECTIONS. What I mean to say is that the MikroTik randomizes what link it will decide to send a connection out of, and you can weight it towards one more than the other. With that being said, the router has no way of knowing, and it does not enter into the decision process, how much bandwidth, length, or total download any one connection will do.
This means you can have 1 person fully utilize one connection and the router may decide to send more connections out of that link based on your rules. However over time, chances are as new connections are made everything will even out for the load across the links.
PLEASE HELP ME FEWI
I have 5 dsl lines
my pcc are
conn1 5/0
Conn2 5/1
Conn5 5/4
I have the same problem please tell me the denominators and remainders
i have band DSL1 5Mb
DSL2 5MB
DSL3 3.5 MB
DSL4 3.5 MB
DSL5 2.5 MB
please help me
http://forum.mikrotik.com/t/pcc-problem/45895/2
