ASK [wireguard]
when in doing wireguard on my windows computer,
I’m able to reach an ip address even if they are not specifically in to allow address.
config is realy simple, also i have to poitn here that between the MikroTik that works well
/interface wireguard
add listen-port=82 mtu=1420 name=WG1
/interface wireguard peers
add allowed-address=10.0.16.10/32 interface=WG1 public-key=“E/6hJgAA76boQS+q4NjyLd9BXnKjTxxxxxxxxxxxxxxx”
In short, no. Allowed addresses act as both incoming and outgoing filter for what can be on the other side. If it’s not listed, it won’t pass.
well definitely for windows pass, unlike MT to MT
got that, needs to be specifically on the WG-Client (same as OVPN) ,by default is 0.0.0.0/0. It’s makes lot of sense,but i thought that i can manage that from the WG-Server
Such misinformation :stuck_out_tongue_winking_eye:
The cryptokeyrouting on the MT, for example, for local traffic entering the tunnel matches outgoing traffic and selects the appropriate peer. NOT FILTERING.
The cryptokeyrouting on the MT, for example, for remote traffic arriving at the router and with intention to exit the tunnel, is compared to the allowed IP peer list and if matched is allowed through FILTERING.
So technically one is matching/selecting, the other is straight filtering.
If you want to better understand anything Wireguard and specfically Allowed IPs…
https://forum.mikrotik.com/viewtopic.php?t=182340
You can but not by means of Wireguard. allowed-address is compared to the destination address of a packet to be sent to the peer, and to source address of a packet received from a peer. So to “manage that at the WG server”, you have to use firewall rules as usually.
but between MT, that works very well.Have you noticed that?
Hvala brate
What exactly works?
One difference between MT and other usual WG clients is that MT has separate allowed addresses and routes. So on MT you can have allowed-address=0.0.0.0/0 (i.e. allow everything), but route only selected subnets you add routes for. Usual WG client would by default automatically add route for whole 0.0.0.0/0 (I think there’s option to not do that).
@Sob
basically i’m saying that allowed-address works only between MikroTik.
For other devices (win/android/ios) i need to do (sindy mentioned) filter rules.
I probably don’t understand what exactly you mean, but again, no, allowed addresses is not anything special in RouterOS, it’s part of WG and works the same everywhere.
