assig public ip to some client
hi dear
i have a mikrotik with these ethers:
ether1:192.168.100.1
ether2,3,4: DHCP-Client (providers gives me 10 Valid IP on each line)
also i have load balancing with fail over
can some of my client have public ip ?
1-client directly give Valid IP from provider
2-i map public ip (DHCP) to invalid ip
3-i map public ip (DHCP) to mac address
i know this command, but i dont have static ip to assign some clients
/ip firewall nat add chain=dstnat dst-address=10.5.8.200 action=dst-nat to-addresses=192.168.100.28
/ip firewall nat add chain=srcnat src-address=192.168.100.28 action=src-nat to-addresses=10.5.8.200
tank you so much
have you upgraded your 2.9.27? =)
yes sir
any replay ???
hi chupaka
you only wanted know that i upgraded my OS or no ?
please answer my question
thank you so much
I think you should use scripting to see whether your IP address via DHCP has been changed and correct your mapping rules accordingly
could you please help me to write this script?
Look at scripting examples
http://wiki.mikrotik.com/wiki/Scripting-examples#Check_if_IP_on_interface_have_changed
