Hello friends,
I have a scenario where: I have my lan network on ether3 and 4, ether3 has ip 172.16.1.1/24 and ether4 has ip 192.168.95.1/24. On the ether1 and ether2 ports I have two ISPs that use pppoe.
I would like to assign an IP to these two pppoe interfaces. One for ISP1 and one for ISP2. For example:
ISP1 pppoe will have IP 192.168.10.1
ISP2 pppoe will have IP 192.168.20.1
Where, the route will first go through my LAN gateway (172.16.1.1 or 192.168.95.1) then go through the ISP1 ip (failover, if ISP1 drops then ISP2 will be up) (192.168.10.1 or 192.168.20.1 ) and then continue the route through the ISP’s backbone.
It’s possible?
When ISP1
1 <1 ms <1 ms <1 ms 172.16.1.1 (MY LAN)
2 <1 ms <1 ms <1 ms 192.168.10.1 (ISP1 - PPPoE Client, no modem/router, direclty Mikrotik)
3 3 ms 3 ms 2 ms 170.xx.200.62.isp.xxx.com.br (Backbone ISP1)
4 3 ms 1 ms 2 ms xxx.xxx.xxx.xxx
5 3 ms 3 ms 2 ms xxx.xxx.xxx.xxx
6 4 ms 3 ms 2 ms xxx.xxx.xxx.xxx
7 15 ms 13 ms 13 ms xxx.xxx.xxx.xxx
8 12 ms 12 ms 12 ms xxx.xxx.xxx.xxx
9 12 ms 12 ms 10 ms xxx.xxx.xxx.xxx
When ISP2
2 <1 ms <1 ms <1 ms 192.168.20.1 (ISP2 - PPPoE Client, no modem/router, direclty Mikrotik)
3 3 ms 3 ms 2 ms 171.xx.201.63.isp.xxx.com.br (Backbone ISP2)
Thanks!!!
