Hello, recently got a hEX RB750Gr3 to expand my home network. I’ve tried setting up different ports to LAN or WAN with various forum post but almost always got incorrect behavior or not being able to connect back to the router.
I’m trying to do this because I have a connection from my ISP that both serves internet access and TV. For TVs to receive data they need to receive an IP address from the ISP hardware (Not through LAN). (I tried playing around with IGMP, but that clearly did no work :D) All other traffic would go through the router as LAN.
(Previously I only had a switch in the same place, and all routing was done by a router/AP combo connected to the switch. Now I have more devices to connect and the simplest way to connect and manage them (without running new ethernet runs) was to switch out the switch for a router)
What I would ideally want:
Ports 2 and 3 - LAN ports, managed by the router (DHCP and all).
Ports 4 and 5 (TVs) - connect to ISP WAN hardware directly/invisibly. Devices on these ports do not interact with LAN devices, do not receive an IP address from the router, all traffic only gets switched.
(Port 1 is connection to WAN/ISP/internet connection)
I’m new to to this, but already played around enough to use WinBox semi confidently.
Would be grateful for directions on how to achieve this. Would be starting from a default configuration (again) on v7.15.3
