assign static ip adress to customers
Hello, I’m new on this type of hardware and I would like to know how I can assign static ip addresses to my customers? I think I would need an ip range submitted by my internet provider and assign them to my customers. How could I do it?
Best regards.
mac address?
but how can I do it in the router? Is there an option to type down the mac address associated to the customer?
Do you use DHCP? You can make static entries for mac addresses your users use … connect to your router via winbox, go to IP / DHCP Server / Leases tab / select an active lease and click “Make static” button.
.. other method would be to use pppoe with radius and have addresses assigned individually via user/pass. Check this link
http://forum.mikrotik.com/t/pppoe-static-ip-address-with-radius/39792/1
JF
Thank you, I will try the first option.
Best regards
