Hello!
Here it is:
add admin-mac=2C:C8:1B:59:93:F0 auto-mac=no comment=defconf name=bridge
add name=nassu_wan
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=estonia disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge name=Deepweb ssid=Deepweb wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX country=estonia distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=DeepwebDisabled wireless-protocol=802.11
set [ find default-name=ether5 ] rx-flow-control=auto tx-flow-control=auto
/interface lte
set [ find ] allow-roaming=yes band=1,3,7,20,8,38,40,41,5,28 name=lte1 network-mode=lte
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.20-192.168.1.254
add name=nassu_wlan_pool ranges=192.168.2.20-192.168.2.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=nassu_wan comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=Deepweb
/ip settings
set accept-redirects=yes accept-source-route=yes
add comment=defconf interface=lte1 list=WAN
/interface lte settings
set external-antenna=auto
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
add address=192.168.2.1/24 interface=nassu_wan network=192.168.2.0
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet disabled=yes
set ssh disabled=yes
set winbox disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=lte1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Tallinn
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
"\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
Is the general idea of how I’m trying to solve my task correct or is there a better way to do it?
Br,
Jansza
