Assigning different functions for interfaces
Dear friends,
Currently my Microtik Router is running on a single bridge and whatever I change like running hotspot or queuing, it effects all the interfaces, I would like to separate my interfaces in order to use them for different tasks, how do I achieve this?
Thanks in advance.
Remove them from the bridge (and, depending on your hardware, from a master port), assign addresses, dhcp-servers/clients, vlans - everythiing you want - to them.
-Chris
Go to bridging and disable the option of bridging all LAN PORT.
Which model of router are you using please.
thanks for the reply, I removed it from the bridge but how do I enable it to receive internet traffic unless its set as slave to the WAN port. If it acts as a slave will queuing work on it?
the model i am currently using is RB1100AHx2
Create a new NAT for this port.
