Assigning Public Block to Clients
I am not new to networking; however, I cannot get this to work!
I have an RB2011UAS with internet using a DSL / PPP connection and all clients, wired and wireless work fine currently. I now want to assign a two of my public IPs to clients.
Here is my layout:
Public IP Block: 63.x.139.168/29
Private IP Pool: 192.168.88.0/24
ETH1 Connected to DSL Modem
ppoe-Qwest PPPoE Client and is issued IP-63.x.131.174 Network-67.5.64.8 by DHCP
ETH2-ETH3 All bridged and natted to 192.168.88.0/24 using public IP 63.x.131.174 (includes wireless port)
ETH4 I want to issue 63.230.139.168
ETH5 I want to issue 63.230.139.169
I have tried many combinations without any success. Any help would be greatly appreciated! My problem may be the configuration of my client machine as well…
–al
It looks as if your ISP probably expects the public block to all be available via the PPPoE interface rather than the block being routed separately - since the PPPoE address is within the public block.
You could try breaking the problem down. e.g. Can you assign one of the other public IPs to a bridge interface in RouterOS then use a SRC NAT rules to have the outbound traffic use that public IP rather than the one directly on the PPPoE interface?
Celtic: Thanks!
Here is the solution that I came up with, it works and I am hoping it is correct.
I added the address/block 63.x.131.168/29 (network 63.x.131.168/29) to ‘ppoe-Qwest’. I then used srcnat and dstnat to forward traffic to-and-from the internal-IP of the machine in question. So, all traffic from the machine uses a dedicated public IP and traffic inbound to that IP is forwarded to the machine.
Pretty sure there is a more elegant, correct solution!
–al
Celtic: Thanks!
–al
