Assigning Secondary IP Address to Mikrotik Interface
I am wondering if there is a way of assigning two IP adresses on the same interface on Mikrotik equipment. I am looking at the setup where you make one interface primary and the other secondary as it is the case with Linux machine or Cisco router.
Hosea.
you can assign more than one IP address to one interface
Yep, just add additional IPs. I think the additional ips, if on the same subnet, should be /32’s.
Sam
Thanks. It indeed works :slight_smile:
hosea
