Hi All,
I have hEX S as my home router and 2 Audience units.
I would like to configure them so the Wireless clients will be part of a specific VLAN - 200.
Currently, my hEX S router is connected to a single Audience AP with RouterOS 6 installed.
Wifi + VLAN are configured well, everything works fine.
But I would like:
A. To setup a Mesh wifi (as I don’t have wifi signal everywhere at my apartment)
B. Update the Audience RouterOS to the latest stable version.
I configured the Wireless Datapath VLAN parameter, but it seems that it is not supported anymore with RouterOS 7, How can I solve it? Am I doing anything wrong?
BTW, I’m using the wifi-qcom-ac package with my Audience devices.
I would not like to use CAPsMAN as I understood it does not support Mesh wifi.
My end goal is to have a Mesh wifi (single, extended wifi - using the same SSID and network configuration) between both Audience devices.
Related Router configuration
# RouterOS 7.19.4
add admin-mac= auto-mac=no comment="Default bridge" name=bridge port-cost-mode=short/interface ethernet
set [ find default-name=ether1 ] comment="Living room AP" name=ETH1
set [ find default-name=ether5 ] comment="Office AP" name=ETH5 poe-out=off/interface vlan
add interface=bridge name=vlan200 vlan-id=200/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN/ip pool
add name=dhcp_pool200-HASS ranges=192.168.200.30-192.168.200.100
add name=dhcp_pool-LAN ranges=192.168.0.100-192.168.0.240/ip dhcp-server
add add-arp=yes address-pool=dhcp_pool200-HASS interface=vlan200 lease-time=1h name="dhcp 200-HASS"
add add-arp=yes address-pool=dhcp_pool-LAN interface=bridge lease-time=1h name="dhcp LAN"/interface bridge port
add bridge=bridge ingress-filtering=no interface=ETH4 internal-path-cost=10 path-cost=10
add bridge=bridge ingress-filtering=no interface=ETH5 internal-path-cost=10 path-cost=10
add bridge=bridge ingress-filtering=no interface=ETH2 internal-path-cost=10 path-cost=10
add bridge=bridge ingress-filtering=no interface=ETH3 internal-path-cost=10 path-cost=10
add bridge=bridge ingress-filtering=no interface=ETH1 internal-path-cost=10 path-cost=10 trusted=yes/interface bridge vlan
add bridge=bridge vlan-ids=200/interface wireless cap
set bridge=bridge caps-man-addresses=192.168.0.1/ip address
add address=192.168.0.1/24 interface=bridge network=192.168.0.0
add address=192.168.200.1/24 interface=vlan200 network=192.168.200.0
add address=192.168.211.1/29 interface=lo network=192.168.211.0/ip dhcp-server lease
add address=192.168.0.31 address-lists="MikroTik AP,MikroTik Devices" client-id= mac-address= server="dhcp LAN"
add address=192.168.0.32 address-lists="MikroTik AP,MikroTik Devices" client-id= mac-address= server="dhcp LAN"/ip dhcp-server network
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.7 domain= gateway=192.168.0.1 netmask=24
add address=192.168.200.0/24 dns-server=192.168.0.7 domain= gateway=192.168.200.1 netmask=24
Related Audience configuration (the one with Router OS 7)
# RouterOS 7.20.1
add name=bridge port-cost-mode=short vlan-filtering=yes
/interface vlan
/interface wifi channel
add band=2ghz-n disabled=no frequency=2417 name=2GHz skip-dfs-channels=all width=20mhz
/interface wifi datapath
add bridge=bridge disabled=no interface-list=dynamic name=Default vlan-id=200
/interface wifi security
add disabled=no name=Default
/interface wifi configuration
add channel=2GHz country=Greece datapath=Default disabled=no distance=1 mode=ap name="IoT2.4GHz" security=Default ssid=IoT2.4
/interface wifi
# vlan-id configured, but interface does not support assigning vlans
set [ find default-name=wifi1 ] channel.frequency=2417 configuration="IoT2.4GHz" configuration.mode=ap
add bridge=bridge ingress-filtering=no interface=ether1 internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge ingress-filtering=no interface=wifi1 internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge tagged=bridge,ether1 vlan-ids=200
/ip dhcp-client
# DHCP client can not run on slave or passthrough interface!
add add-default-route=no default-route-tables=main interface=ether1
Thanks in advance
