Assistance with NAT issues to specific addresses
I have strange NAT issue that I am trying to solve and will appreciate any help or guidance you can provide.
I have external network where my routers are connected. It is on 10.0.p.0/24 subnet with IPs of 10.0.0.138 & 10.0.0.254 . On my mikrotik router I have the address 10.0.0.199 as you can see:
5   ;;; External
     address=10.0.0.199/24 network=10.0.0.0 interface=bridge1
     actual-interface=bridge1
I am able to ping from the mikrotik itself to the two routers:
[admin@rtr-mt-main] > ping 10.0.0.138
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 10.0.0.138                                 56  64 0ms
    1 10.0.0.138                                 56  64 0ms
    2 10.0.0.138                                 56  64 0ms
    sent=3 received=3 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
[admin@rtr-mt-main] > ping 10.0.0.254
    0 10.0.0.254                                 56  64 6ms
    1 10.0.0.254                                 56  64 2ms
    2 10.0.0.254                                 56  64 2ms
    3 10.0.0.254                                 56  64 2ms
    sent=4 received=4 packet-loss=0% min-rtt=2ms avg-rtt=3ms max-rtt=6ms
The routing is working fine and I am able to connect to the internet from all devices in my network through both routers. I have two routes with different AD numbers to allow redundancy.
You can see output of tracert from my home machine going out from both routers:
tracert -d 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  192.168.2.254
  2    <1 ms    <1 ms    <1 ms  10.0.0.138
  3    10 ms    19 ms    19 ms  215.180.37.1
  4    13 ms    13 ms    15 ms  10.250.0.162
  5    10 ms     9 ms    10 ms  212.25.77.2
  6    10 ms    10 ms     9 ms  10.90.99.9
  7    48 ms    48 ms    48 ms  74.125.51.88
  8    48 ms    48 ms    48 ms  74.125.244.209
^C
tracert -d 9.9.9.9
Tracing route to 9.9.9.9 over a maximum of 30 hops
  2     3 ms     3 ms     3 ms  10.0.0.254
  3    75 ms    54 ms    42 ms  10.21.30.179
  4   199 ms    64 ms    39 ms  10.21.30.161
  5    46 ms    59 ms    37 ms  10.21.111.11
^C
The issue is , I am unable to connect to the two routers directly from my network:
ping 10.0.0.138
Pinging 10.0.0.138 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.0.0.138:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
tracert -d 10.0.0.138
Tracing route to 10.0.0.138 over a maximum of 30 hops
  2     *        *        *     Request timed out.
  3     *        *        *     Request timed out.
  4  ^C
(192.168.2.254 is one of the mikrotik IPs)
I checked the firewall rules and NAT rules , but i don’t see anything that would block me from access the two routers:
[admin@rtr-mt-main] > ip firewall filter print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; Access from home computer to external bridge
      chain=forward action=accept src-address=192.168.2.191
      dst-address=10.0.0.0/24 log=no log-prefix=""
[admin@rtr-mt-main] > ip firewall nat print
 6    ;;; NAT to External network
      chain=srcnat action=src-nat to-addresses=10.0.0.199
      out-interface=bridge1 log=no
I have no idea what could be the problem or what more can I check . It used to work , but for some reason it stopped. I am not sure when and I tried reverting configuration to old backup , but it did not help. Since all traffic is working as it should, I only notice this issue when trying to access the external routers directly to change configuration , and it only happens once in a blue moon, so no idea what was changed.
Please , any help will be appreciated.
Also - this is my second posting as the last one was probably rejected (hoping this will not happen again)
Thanks.
The order of rules in the firewall matters, they are evaluated from the first (topmost) one towards the last (bottommost) one in each chain until first match. So some rule in the srcnat chain before the one you have posted may shadow the one you have posted. So better follow the hint in my automatic signature below.
