Assitance getting incoming VPN firewall settings working
I’ve recently installed my LTE 6E SXT kit and have even managed to get the networks bonded and have seen speeds of 140mbps on EE network 600m from a mast.
I’m very happy with those speeds.
The Mikrotik 4g unit is still connected back into my router so that i can use the ADSL as failover,
Due to acessing internet via 4G and no longer ADSL, i need to forward web traffic (and other ports)back through a VPN that offers fixed IP as the 4G connection uses CGNAT
Ive found a supplier for this and have created the connection to it using the PPTP VPN client in winbox
This is where i am struggling
Despite having quite a bit of IT experience, I’m struggling to get it to forward the traffic back through the VPN into my internal network which is due, i think, to all the various address lists involved.
There are plenty of site to site VPN walkthroughs online, but they dont quite apply, neither do setting up VPN clients
I can see the incoming traffic hitting the VPN connection as the RX counter is increasing, but it wont go back the other way
The public IP is 81.x.x.x
Theres a server connection that i connect to using the L2TP client
This then connects on the VPN range 192.168.89.1 and with a remote server IP of 10.10.1.1
The bond IP is on 192.168.88.0/24
Finally I need to forward this back to 192.168.88.253, which is my internal router
I know the draytek firewall is set up correctly as it forwards correclty on incoming ADSL connections
If someone can tell me where i am going wrong and assit with configuring, that’d be great
Heres my outputs
NOTE: Ive only been mesing with the PRTG port before i make changes to the other incoming ports
/ip firewall address-list
add address=10.10.1.1 list=rapidvpn-pptp
add address=192.168.89.1 list=rapid-vpn-local
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=accept chain=input comment=“allow IPsec NAT” dst-port=4500 protocol=udp
add action=accept chain=input comment=“allow IKE” dst-port=500 protocol=udp
add action=accept chain=input comment=“allow l2tp” dst-port=1701 protocol=udp
add action=accept chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add action=accept chain=input comment=“allow sstp” dst-port=443 protocol=tcp
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment=http dst-port=80 in-interface=lte1 log=yes protocol=tcp to-addresses=192.168.88.253 to-ports=80
add action=dst-nat chain=dstnat comment=https dst-port=443 in-interface=lte1 log=yes protocol=tcp to-addresses=192.168.88.253 to-ports=443
add action=dst-nat chain=dstnat comment=Openvpn dst-port=1194 in-interface=lte1 log=yes protocol=udp to-addresses=192.168.88.253 to-ports=1194
add action=dst-nat chain=dstnat comment=Plex dst-port=32400 in-interface=lte1 log=yes protocol=tcp to-addresses=192.168.88.253 to-ports=32400
add action=dst-nat chain=dstnat comment="PRTG " dst-port=400 in-interface=rapidVPN-pptp log=yes protocol=tcp src-address-list=rapidvpn-pptp to-addresses=192.168.88.253 to-ports=400
