Hi all,
I have a question regarding asymmetric 1-to-1 NAT. Is it possible with Mikrotik router?
My current test scheme below:
bridge_address: 10.10.10.10/32
192.168.0.1/24 10.0.0.1/24
NAT1_Router
192.168.0.10/24/ \ 10.0.0.10/24
Inside_Router Outside_Router
NAT2_Router
192.168.0.2/24 10.0.0.2/24
Network 192.168.0.0/24 is in vlan 10.
Network 10.0.0.0/24 is in vlan 20.
My goal is:
- Outside_Router sends packet to address 10.10.10.10 via NAT1_Router
- NAT1_Router makes dst-nat, changing destination address 10.10.10.10 to 192.168.0.10
- Inside_Router receives packet and sends reply back to 10.0.0.10 but not via NAT1_Router, it sends packet to NAT2_Router.
- NAT2_Router must translate this packet back with src-nat, changing source address 192.168.0.10 to 10.10.10.10.
Problem is, NAT2_Router does not provide NAT translation for local address 192.168.0.10 to address 10.10.10.10. As a result, Outside_Router receives replies with source IP address 192.168.0.10, not 10.10.10.10.
Inside_Router configuration:
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
add address=192.168.0.10/24 interface=vlan10 network=192.168.0.0
add distance=1 dst-address=10.0.0.0/24 gateway=192.168.0.2
/system identity
set name=Inside_Router
NAT1_Router configuration:
add name=br-nat-1
/interface vlan
add interface=ether1 name=vlan20 vlan-id=20
add address=192.168.0.1/24 interface=vlan10 network=192.168.0.0
add address=10.0.0.1/24 interface=vlan20 network=10.0.0.0
add address=10.10.10.10 interface=br-nat-1 network=3.3.3.3
add action=netmap chain=dstnat dst-address=10.10.10.10 to-addresses=192.168.0.10
add action=netmap chain=srcnat src-address=192.168.0.10 to-addresses=10.10.10.10
/system identity
set name=NAT1_Router
NAT2_Router configuration:
add name=br-nat-1
/interface vlan
add address=192.168.0.2/24 interface=vlan10 network=192.168.0.0
add address=10.0.0.2/24 interface=vlan20 network=10.0.0.0
add address=10.10.10.10 interface=br-nat-1 network=10.0.0.0
/system identity
set name=NAT2_Router
Outside_Router configuration:
/interface vlan
add address=10.0.0.10/24 interface=vlan20 network=10.0.0.0
add distance=1 dst-address=10.10.10.10/32 gateway=10.0.0.1
/system identity
set name=Outside_Router
Appreciate your help.
