I am running a MikroTik RB4011 on XGS-PON w/ BGW320. I have IP-Passthrough via Manual mode working well for IPv4 (I defined the gateway, subnet mask, and IPV4 statically on the router).
The only issue seems to be my IPv6.
I tried reusing it the way I had my RB4011 IPv6 w/ bypass, which is to have the RB4011 pull the entire /60 prefix, then give each of my VLANs a /64 prefix. That doesn’t seem to be possible since the AT&T RG is hoarding the /60.
What do I need to do to get IPv6 working? Without IPv6 I’m noticing some sites that a few friends run (IPV6 only VPS/nginx) acting pretty wonky. Wasn’t sure if there is a solution already, I googled around and searched DSLReports but I don’t really see a guide or much info that is relevant, most is about bypass.
Thanks to anyone that reads, and thanks again for those that have some suggestions.
EDIT: It seems the solution a pfSense guy found was to request multiple /64’s individually from his WAN interface. MikroTik doesn’t allow this in RouterOS 6 from what I can see, it is telling me only one DHCP6 client per interface.
