ribaro
July 20, 2006, 11:33am
1
Hi all,
i have strange problem with one Proxim Tsunami mPCI card installed on daughterboard with RB532. In /system resource I can see the card recognized, in /drivers the Atheros 5211 is loaded but in wireless interfaces the interface doesn’t show up. I’ve tried the same card on one RB112 and it works fine. Is the daughterboard the reason or I miss something here?. The version of RouterOS on RB532 is 2.9.27 and on RB112 is 2.9.24. I’ve tried to downgrade the 532 to 2.9.23, but got the same problem.
ribaro
July 20, 2006, 11:40am
2
> system resource pci print detail
0 device="00:0b.0" name="AR5211 802.11ab NIC (rev: 1)" vendor="Atheros Communications, Inc."
category="Ethernet controller" vendor-id="0x168c" device-id="0x0012" irq=141
1 device="00:05.0" name="AR5212 802.11abg NIC (rev: 1)" vendor="Atheros Communications, Inc."
category="Ethernet controller" vendor-id="0x168c" device-id="0x001b" irq=143 memory=0x50020000-0x5002FFFF
2 device="00:04.0" name="AR5212 802.11abg NIC (rev: 1)" vendor="Atheros Communications, Inc."
category="Ethernet controller" vendor-id="0x168c" device-id="0x001b" irq=142 memory=0x50010000-0x5001FFFF
3 device="00:03.0" name="VT6105 [Rhine-III] (rev: 134)" vendor="VIA Technologies, Inc." category="Ethernet controller"
vendor-id="0x1106" device-id="0x3106" irq=143 memory=0x50000100-0x500001FF io=0x18800100-0x188001FF
4 device="00:02.0" name="VT6105 [Rhine-III] (rev: 134)" vendor="VIA Technologies, Inc." category="Ethernet controller"
vendor-id="0x1106" device-id="0x3106" irq=142 memory=0x50000000-0x500000FF io=0x18800000-0x188000FF
5 device="00:00.0" name="IDT79RC32434 (rev: 0)" vendor="Integrated Device Technology, Inc."
category="Non-VGA unclassified device" vendor-id="0x111d" device-id="0x0000" irq=140 io=0x18800000-0x188000FF
This is output from the router. There are all the three interfaces recognized but the first - device=“00:0b.0” is missing from other menus …
ribaro
July 20, 2006, 2:25pm
3
Problem solved!
I’ve chaged the card with Atheros 5413 based card and all works fine. Seems like the Proxim card is not compatible with this RB.
I have a problem that hopefully someone out there can give me some advice
I have a computer conberted to Mikrotik and I have installed a
Planet PCI 802.11g wireless card and I cannot see it in the
interface to enable it
How I am going to make it work
Thanking you in advance
Lawrence
djape
July 24, 2006, 8:57am
5
What chipset is on this Planet card?
If it’s atheros it should work without problems, but Planet also uses Marwell chipset which doesn’t work on MT.
Cheers…
