After I upgraded couple of my ruterboards to RouterOS 3.2 all my links on Atheros 5213 stopped working. Links on Atheros 5413 works fine. I use WDS (APBridge-WDSSlave).
The only solution is to downgrade to OS 2.x which doesn’t go smoothly either. After downgrading all wireless cards are disabled and resetted so I need to perform config restore.
Anyway something’s wrong with this new OS.
What configuration you have. And what you mean with ‘stopped working’, we need more information?
After upgrade it just disconnects and can’t connect until I downgrade.
Client config:
interface wireless
name=“wlan1” mtu=1500 mac-address=00:0B:6B:35:EF:70 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“smil” mode=wds-slave ssid=“001025-001161” area=“”
frequency-mode=regulatory-domain country=poland antenna-gain=0
frequency=5520 band=5ghz scan-list=5500-5700 rate-set=configured
supported-rates-b=“”
supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=“”
basic-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-b wds-mode=static wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
hw-retries=15 preamble-mode=both compression=no allow-sharedkey=no
interface wireless wds
name=“wds1” mtu=1500 mac-address=00:0B:6B:35:EF:70 arp=enabled disable-running-check=no
master-interface=wlan1 wds-address=00:0E:8E:0A:30:9B
AP Config:
interface wireless
name=“wlan2” mtu=1500 mac-address=00:0E:8E:0A:30:9B arp=enabled
radio-name=“ss2-mil” mode=ap-bridge ssid=“001025-001161” area=“”
frequency=5520 band=5ghz scan-list=5520-5560 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a
wds-mode=static wds-default-bridge=none wds-default-cost=100
wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
name=“wds2” mtu=1500 mac-address=00:0E:8E:0A:30:9B arp=enabled
disable-running-check=no master-interface=wlan2
wds-address=00:0B:6B:35:EF:70
try setting the rate-set to default.
Please make the support output file this links stops working. Send it to support@mikrotik.com
Is this happening on the WDS-slave router or on the Main AP?
This is happening after Main AP Upgrade.
But I have another link which behaves differnetly.
In that case Main AP has Atheros 5413 but WDS Slave (RB 133) has Atheros 5312. When I upgrade WDS Slave it connects to AP but there’s no WDS link and after couple of seconds RB disconnets my session (telnet, winbox or ssh). I need to reboot to connect againg to RB but after a while it happens again. And so on until I downgrade to 2.x.
There is another strange thing on OS 3.x. On RB with multiple wirless cards, when I disable and enable one of the card, all other links disconnects and then reconnects after couple of seconds.
After further investigation it turned out it’s a RB133 problem, not Atheros. I tested it on couple of RB133s. Whatever wireless card is installed after upgrade of RB133 to 3.x WDS links stop working. Normal AP-Station mode works OK but after adding WDS problems begin (ICMP loss, terminal disconnecting etc.) making MT unstable.
Odd. I am using two RB133c with XR9 for a WDS bridge, upgraded from 2.9.46 through the RC’s and up to 3.3 without issue.
RB133 or R133c? Just a single card, if its a RB133?
Sorry, I meant RB112 all the time. I don’t know where that mistake came from, I don’t even have any RB133…
