We are/were in the process of changing our Prism APs to Atheros APs. The primary reason for this is that WDS on Prism APs broke in 2.9.5 and Mikrotik appears unwilling to acknowledge it, much less fix it. Not to mention that all new development seems to surround the Atheros cards and not the Prism cards.
We operate in a wide area network environment with clients up to about 15 miles from a tower in point-to-multipoint fashion. APs typically have up to 60 clients on them.
We converted one site with two sectors over, and things went pretty well. Some clients had to power-cycle their CPE before they would reassociate. But other than that, everything went okay.
We then proceeded to convert another site that had four sectors. On rare occasion, ONE client would associate, but then drop from the registration table a minute later. Meanwhile, there were two hundred clients trying to associate. If we put one of the sectors into sniff mode, we could see beacons being generated from the Atheros APs, and we could see tons of probe requests from clients. But no one would associate.
During this time, the two sectors that we previously converted to Atheros on another nearby tower and were working fine for four days stopped accepting new associations. This tower is closeby enough to the tower we were working on that many clients can see both towers. Since the tower we were working on with four sectors went down, it stands to reason that the clients who could “see” this other tower would try and associate there. But the Atheros APs on this tower stopped accepting new registrations. After resetting this AP, no one associated with it either.
We normally have default auth and default forward off and use RADIUS MAC Authentication. We turned default auth on and turned off the RADIUS MAC Authentication, making the system completely open, and still no one could associate on either tower
After hours of endless fiddling and rebooting, we reverted back to Prism cards, and everything came up instantly.
Has anyone seen anything like this before? Is there an issue with Atheros APs where they cannot function when there are too many association requests all at once? These are Atheros 5413 cards, if its important.
Thanks in advance for any ideas/help/suggestions you can offer.
Dave
