atheros AR5212 PCI problem
Hi all
I use MT OS version 2.9.6 installed on PC Engines GmbH and Atheros AR5212 PCI card. I have a strange problem. Sometimes AR5212 PCI card is regconized and sometimes not regconized.
If i unplug the power or shutdown MT OS then put the power on, the card is not regconized. But if i click System → Reboot. after rebooting the card is regconized. i try to reboot again and again the card is still regconized.
So the card is not regconized only if i unplug the power or shutdown MT OS.
please help.
thanks
2.9.6… Pretty old… try to upgrade and see if the problem disappears
Hi
I tried to upgrade to 2.9.24 but the same problem still occur.
thanks
What card are you using ?
Have you updated the WRAP bios to latest version, I had to do that to get it working with wlm54g card and its a AR5212.
The bios update fixes a timing issue.
