Atheros lan chipset support
Hi!
I have a Asrock motherboard with Atheros AR8131L family lan chipset, but the lan not work under mikrotik.
Available mikrotik support or driver?
Thanks, Steve.
ps: sorry my english
The latest drivers are included at v5.0rc7 version. If NIC does not work there, there is nothing we can do currently.
Thanks for fast answer.
I tryed the V5.0rc7, but that not recognized the lan chip.
Possible compile a new kernel with atheros lan support and insert to the mikrotik?
Currently there is no such plans. Perhaps support will be added in the future.
Available the config (.config file) of the Mikrotik OS 4.16 x86 stable kernel?
I will try to recompile the kernel with atheros support.
Walk this road?
gala,
No.
OK. Thanks
