My god! Look this card, in the page say is compatible with Mikrotik ![]()
400mW at 54Mbps ![]()
630mW at 1Mbps ![]()
Here in english
Regards!
Alessio
Here in english
Regards!
Alessio
We have one of those cards, and tested it a few months back.
There is an โAโ version which is even more interesting.
The โAโ version does work in Mikrotik, with good clean high-speed throughput. The chipset is the same as CM9, just with a high power TX amplifier.
We did have stability/throughput problems with the โb/gโ card, though the โAโ was fine. Not sure why that is.
However, I did not have the test equipment to verify the actual โhigh powerโ figures on either. I think the 630mW claim is actually exaggerated - rather unlikely it is anything like that. And the throughput was bad on the b/g, which we didnโt get to the bottom of, but I suspect non-linearity in the power amp causing the problems with the high-order OFDM modulation rates.
Regards
CableFree Solutions.
Thanks for the link provided, Iยดll check it out
