ATL 5G R16 internet avaliable on LTE1 ( Limited access)
after restart internet back and normal
Internet gone overnight on the morning, looks like switches to limited when not in active use
Is there script, to reboot ATL 5G modem when no internet?
Usually internet connection on LTE interfaces can be reset by disabling and the re-enabling the interface after a small timeout, see:
Hi!
When I reset, then internet is back, but later it turns to limited.
Yep, it happens.
Is the "later" meaning a few seconds, minutes, hours?
It could be also something on the side of the ISP (as an example only) here in Italy the ISP Wind 3 resets IP address every 4 hours and this "disturbs" Mikrotik devices (but it usually works fine with other LTE devices, where the issue never happens).
Hi Jaclaz !
Greetings from Estonia !
I can say that it looks like more than minutes, almost hours.
When I am using actively internet, its OK, speed is decent 3-15 MB, ping around 30.
problem in morning that smart switches ( TUYA ) all offline.
and cant monitor during day what happens.
I switched ISP like 2 months ago, noticed issues this week.
I try to use Your script code ![]()
And I am novice at Mikrotik and also programming…
All the Best !
Andrus
I would try first running for a few days a netwatch script only logging the connection (and disconnection) to understand if it is something that happens "casually/randomly" or periodically.
Depending on the results it may be more suitable a Netwatch script or a scheduled task, resetting the LTE interface (say) every morning at 4:50.
See also:
New mikrotik chateau 5g r17 ax
