ATL LTE IPv6 passthrough
Hello!
I’m using a Mikrotik ATL LTE in front of a Mikrotik L009 which is the main router. The LTE device is configured in passthrough mode. The L009 correctly receives IPv4 addressing from the CGNAT pool of the provider. I can see with the “/interface lte at-chat lte1 input=AT+CGPADDR” command that the modem of the ATL correctly receives IPv4 and IPv6 addressing but I’m unable to use the IPv6 address on the L009, neither with the DHCPv6 client nor when configuring the IPv6 address and routing table manually.
According to the documentation, the device should be able to pass through IPv4 and IPv6. In other forum posts, it was advised that it is crucial to set “use-network-apn=no” and manually specify the APN, which I did. However this did not help.
Did I miss something in the configuration? Is the firewall configuration even necessary on the LTE device since everything is passed on ether1 anyway? What would be a basic default configuration to configure IPv4+IPv6 passthrough on the devices?
Here are the relevant parts of my configuration:
Mikrotik ATL LTE:
/interface lte set [ find default-name=lte1 ] allow-roaming=no band="" pin=xxxx
/interface vlan add comment=99_MGMT interface=ether1 name=vlan99 vlan-id=99
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface lte apn set [ find default=yes ] add-default-route=no apn=web.vodafone.de passthrough-interface=ether1 passthrough-mac=auto use-network-apn=no use-peer-dns=no
/port set 0 name=serial0
/queue type add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface set ether1 queue=fq-codel-ethernet-default
/ip neighbor discovery-settings set discover-interface-list=LAN
/interface list member add comment=defconf interface=ether1 list=LAN
/interface list member add comment=defconf interface=lte1 list=WAN
/interface list member add comment=MGMT interface=vlan99 list=LAN
/ip address add address=10.110.99.1/24 comment=99_MGMT interface=vlan99 network=10.110.99.0
/ip dns set servers=10.110.99.254
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
/ip firewall filter add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip hotspot profile set [ find default=yes ] html-directory=hotspot
/ip ipsec profile set [ find default=yes ] dpd-interval=2m dpd-maximum-failures=5
/ip route add disabled=no dst-address=10.110.0.0/16 gateway=10.110.99.254 routing-table=main suppress-hw-offload=no
/ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.110.99.254 routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list add address=::/128 comment="defconf: unspecified address" list=bad_ipv6
/ipv6 firewall address-list add address=::1/128 comment="defconf: lo" list=bad_ipv6
/ipv6 firewall address-list add address=fec0::/10 comment="defconf: site-local" list=bad_ipv6
/ipv6 firewall address-list add address=::ffff:0.0.0.0/96 comment="defconf: ipv4-mapped" list=bad_ipv6
/ipv6 firewall address-list add address=::/96 comment="defconf: ipv4 compat" list=bad_ipv6
/ipv6 firewall address-list add address=100::/64 comment="defconf: discard only " list=bad_ipv6
/ipv6 firewall address-list add address=2001:db8::/32 comment="defconf: documentation" list=bad_ipv6
/ipv6 firewall address-list add address=2001:10::/28 comment="defconf: ORCHID" list=bad_ipv6
/ipv6 firewall address-list add address=3ffe::/16 comment="defconf: 6bone" list=bad_ipv6
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ipv6 firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
/ipv6 firewall filter add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
/ipv6 firewall filter add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
/ipv6 firewall filter add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept HIP" protocol=139
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
/ipv6 firewall filter add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
/ipv6 firewall filter add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd set [ find default=yes ] disabled=yes hop-limit=64 interface=ether1
/system clock set time-zone-name=Europe/Berlin
/system identity set name=wan
/system routerboard settings set auto-upgrade=yes
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
Mikrotik L009:
/interface vlan add comment=99_MGMT interface=ether1 name=vlan99_MGMT vlan-id=99
/disk settings set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface list member add comment=defconf interface=ether1 list=WAN
/interface list member add comment=99_MGMT interface=vlan99_MGMT list=LAN
/ip address add address=10.110.99.254/24 comment=99_MGMT interface=vlan99_MGMT network=10.110.99.0
/ip cloud set update-time=no
/ip dhcp-client add comment=defconf default-route-tables=main interface=ether1
/ip dns set allow-remote-requests=yes
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/ipv6 dhcp-client add add-default-route=yes default-route-tables=main interface=ether1 pool-name=wan request=address,prefix
/system clock set time-zone-autodetect=no time-zone-name=Europe/Berlin
/system identity set name=gw
/system ntp client set enabled=yes
/system ntp server set enabled=yes
/system routerboard settings set auto-upgrade=yes enter-setup-on=delete-key
/tool mac-server set allowed-interface-list=none
/tool mac-server mac-winbox set allowed-interface-list=none
Thank you!
