ATL LTE18 kit - no Winbox - no Webfig
Hello All,
my first post here
for my first RouterOs device… an ATL LTE18
I experienced for two times the impossibility to reach the router even searching neighbor on winbox…
the first time…
It’ was a bit tricky to connect the LTE, I had to modify the the default APN instead of adding another one.
after LTE successful connection, I set a simple DHCP server config, with some lease reservation.. than I was trying to forward some port in order to expose my HomeAssistant, probably from qucksetup menu… (I think I forwarded 8123 TCP and also same 8123 UDP) after that :
:frowning: no more winbox discoverability even if i was still surfing…
ok so… 5sec on reset button, green flash blinking and started from default…
again : APN modification → Done LTE OK ,
DCHP reservation → Done (…let me find a way to save settings… I Found it )
Exported on desktop → Done
Let me check …mmm RouterBoard V7.11 running V7.8 Upgrade!
“You need to reboot”… Ok rebooted !
:frowning: no more winbox discoverability…
What I’m doing wrong?
thank you for your time
Regards
