So I have a network where I want AP management on VLAN 11, switch management on VLAN 10 and several other hundred VLANs for residents that are dynamically assigned by other equipment and software. Our typical brocade configuration that functions is the following but we are looking to replace them with a heat-resistant alternative:
vlan 1 name DEFAULT-VLAN by port
vlan 10 name Switch_Management by port
tagged ethe 1/1/1 to 1/1/48 ethe 1/2/1
no spanning-tree
management-vlan
default-gateway 10.0.3.1 1
vlan 11 name AP_Management by port
no spanning-tree
vlan 20 name Guest_SSID by port
no spanning-tree
vlan 50 name Resident_SSID by port
no spanning-tree
vlan 999 name ISP_WAN by port
vlan 1000 name CALEA by port
vlan 2000 by port
no spanning-tree
vlan 2001 by port
no spanning-tree
vlan 2002 by port
no spanning-tree
This goes on for several hundred VLANs
system-max vlan 4095
aaa authentication login default local
console timeout 5
hostname FDF7_Switch-MDF
ip address 10.0.5.7 255.255.248.0
no ip dhcp-client enable
logging host CENSORED
logging facility local6
no telnet server
interface ethernet 1/1/1
port-name E155_Switch-Unit-16A
interface ethernet 1/1/2
port-name E156_Switch-Unit-16B
interface ethernet 1/1/3
port-name E157_Switch-Unit-16C
interface ethernet 1/1/4
port-name E158_Switch-Unit-16D
interface ethernet 1/1/5
port-name E159_Switch-Unit-16E
interface ethernet 1/1/6
port-name E160_Switch-Unit-16F
interface ethernet 1/1/7
port-name E161_Switch-Unit-16G
interface ethernet 1/1/8
port-name E162_Switch-Unit-16H
interface ethernet 1/1/9
port-name E163_Switch-Unit-16J
interface ethernet 1/1/10
port-name E164_Switch-Unit-16K
interface ethernet 1/1/11
port-name E165_Switch-Unit-16L
interface ethernet 1/1/12
port-name NOT IN USE
interface ethernet 1/1/13
port-name E166_Switch-Unit-17A
interface ethernet 1/1/14
port-name E167_Switch-Unit-17B
interface ethernet 1/1/15
port-name E168_Switch-Unit-17C
interface ethernet 1/1/16
port-name E169_Switch-Unit-17D
interface ethernet 1/1/17
port-name E170_Switch-Unit-17E
interface ethernet 1/1/18
port-name E171_Switch-Unit-17F
interface ethernet 1/1/19
port-name E172_Switch-Unit-17G
interface ethernet 1/1/20
port-name E173_Switch-Unit-17H
interface ethernet 1/1/21
port-name E174_Switch-Unit-17J
interface ethernet 1/1/22
port-name E175_Switch-Unit-17K
interface ethernet 1/1/23
port-name E176_Switch-Unit-17L
interface ethernet 1/1/24
port-name E177_Switch-Unit-18A
interface ethernet 1/1/25
port-name E178_Switch-Unit-18B
interface ethernet 1/1/26
port-name E179_Switch-Unit-18C
interface ethernet 1/1/27
port-name E180_Switch-Unit-18D
interface ethernet 1/1/28
port-name E181_Switch-Unit-18E
interface ethernet 1/1/29
port-name E182_Switch-Unit-18F
interface ethernet 1/1/30
port-name E183_Switch-Unit-18G
interface ethernet 1/1/31
port-name E184_Switch-Unit-18H
interface ethernet 1/1/32
port-name E185_Switch-Unit-18J
interface ethernet 1/1/33
port-name E186_Switch-Unit-18K
interface ethernet 1/1/34
port-name E187_Switch-Unit-18L
interface ethernet 1/1/35
port-name E188_Switch-Unit-19A
interface ethernet 1/1/36
port-name E189_Switch-Unit-19B
interface ethernet 1/1/37
port-name E190_Switch-Unit-19C
interface ethernet 1/1/38
port-name E191_Switch-Unit-19D
interface ethernet 1/1/39
port-name E192_Switch-Unit-19E
interface ethernet 1/1/40
port-name E193_Switch-Unit-19F
interface ethernet 1/1/41
port-name E194_Switch-Unit-19G
interface ethernet 1/1/42
port-name E195_Switch-Unit-19H
interface ethernet 1/1/43
port-name E196_Switch-Unit-19J
interface ethernet 1/1/44
port-name E197_Switch-Unit-19K
interface ethernet 1/1/45
port-name E198_Switch-Unit-19L
interface ethernet 1/1/46
port-name E199_Switch-Unit-20A
interface ethernet 1/1/47
port-name E200_Switch-Unit-20B
interface ethernet 1/1/48
port-name E201_Switch-Unit-20C
interface ethernet 1/2/1
port-name Uplink FDF1_Switch-MDF
interface ethernet 1/2/2
disable
interface ethernet 1/2/3
disable
interface ethernet 1/2/4
disable
Can anyone point me in the right direction or show me some examples of accomplishing this same task with a MikroTik, please. Thanks!
