Atualização No-IP por link secundário MK Versão 7
Boa Tarde Pessoal…
Podem ajudar, tenho script no-ip e funciona perfeitamente porém preciso rodar ele apenas no link secundário.
Já tentei alguns scripts indicando o link 2 ether2 e só atualiza pelo link 1.
It’s English based forum, please translate your post and paste it in English.
Good Afternoon Everyone…
Can you help me? I have a no-ip script and it works perfectly, but I need to run it only on the secondary link.
I’ve tried some scripts below link 2 ether2 and it only updates through link 1.
Could you share the script? It would help to diagnose the problem.
My crystal ball suggests that since you’ve got multiple uplinks, you are likely to have also some “policy routing” setup that allows you route a given class of traffic through a particular uplink. The no-ip update script needs to make use of that setup. So posting the no-ip update script alone won’t be enough, you’ll have to post the complete configuration, using the usual obfuscation measures (no passwords, no usernames, replace public/global addresses by meaningful names like my.public.ip.1…)
