Hi there,
I was just wondering if there would be a way to get my RB2011UiAS-RM to produce a continuous, audible noise on one/both of the following scenarios:
- Network cable disconnected from a specific port
- Unable to ping 8.8.8.8 for >30 seconds
So that I am instantly alerted to any network downtime?
Thank you.
No, there is not any way!
Of course it is possible!
You need to write a script that detects the condition and issues a beep command.
And you can schedule this script to run every 30 seconds and perform its action.
I am not going to write this for you, I only want to counter the remark made by @ingdaka.
That’s great to hear, thank you!
I’m very new to MikroTik and my general programming experience is quite limited too - I don’t suppose you could point me in the direction of some guides or tutorials on similar things that I can adapt into this function? I’m guessing it won’t be quite as easy as:
ping 8.8.8.8;
if ping = no reply;
beep;
wait 30s;
ping 8.8.8.8
else:
wait 30s;
ping 8.8.8.8
Thank you in advance.
Go to tools → Netwatch. Add the IP you want to monitor. Write the script you want for both conditions…
https://wiki.mikrotik.com/wiki/Manual:Tools/Netwatch
