Hello People,
Need some advises, how to set my Audience antennas in our environment. Could you give some advises?
I have 2 audience in our place in 2 rooms, the rooms are separated with wall, and windows.
(AP1 small room - lounge, AP2 large room - office, center, HAP AC2 meeting room)
Wifi is CAP-ed, all the audience antennas (2G, 5G low and 5G high frequencies are in use. I have 2 fix clients, i want to fix them to one of the audiences and want smooth rooming for the other cca 20-40 clients to them. The configuration used on antennas set in Wifi/wifi tab.
The channel setup is same for all the AP’s, the frequencies are fixed, all the chanells are 20/40 wide. (on 5Ghz with CE) width settings.
For the 2 fix clients i have made an acl entry, that binds the client to the wanted AP-s wanted 2GHz interface (ACL1 and ACL2 entry as client MAC to AP1), and i made an acl (ACL3) that accepts all the other clients with signal strength is bethween for example -69..120 (any client to any interface)
In my case i see the fix clients with bethween -50 -60 signal level binded to the wanted AP’s. (AP2)
My problem is that all the other clients (5G capable) will connect first to the AP2 (entry point is nearer to that AP), but regarding the wandering of the devices/people, who are standing more closer to the AP1 will be better to connect to that AP.
If i monitor the registration table, i still see, that the devices are connected to AP2, regarding that the people are much nearer to AP1. (Signal level arround -75 or less)
Could someone give me some clues and approach how could be these configuration more sophisticated. Any rtm and docu is also welcomed!
(And sorry for my bad english)
Thank you for any hely in advance, best regards,
Ferenc
